How Google Decides Which Projects to Axe
Terry Olaes
I Used to be the [H] News Guy
If you’re interested in how Google chooses which projects live and which ones die, check out this article in the New York Times. They don’t use the same equation when making the decision since their project base is so diverse but they do look at some key data points.
All of the shuttered projects failed several of Google’s key tests for continued incubation: They were not especially popular with customers; they had difficulty attracting Google employees to develop them; they didn’t solve a big enough problem; or they failed to achieve internal performance targets known as “objectives and key results.”
With the exception of search all of their products are open to cut. Eternal Beta + Free == Makes No Money.
Google - one trick pony. They're learning that now and why it sucks.
