Just get a native SSD. Far less trouble and things to go wrong
Basicly, is it worth getting one if the main storage is SSD anyways? For £37 extra is it worth it?
And make sure it is from a reliable manufacturer and is at minimum 128GB in size.
I'm dealing with an HP laptop where booting off the SSD isn't enabled in the EFI.
vouche for intelIntel RST works pretty well . I've used it on laptops and it's definitely better than not having it.
