How fragile are LCD monitors?
Great2bfree
How fragile are LCD monitors? Will pressing on the screen damage/break it?
What about the cleaning it? can it be clean as a crt monitor?; water and a piece of cloth.
One more, How long does the LCD last untill it starts to give problem; dead pixels, artefacts.ect.
after 2 years?
LCD's are fragile and I would not recomend pushing on the screen...you will see all these prety colors and with any luck nothing will be damaged BUT.....this is a glass sandwich that has liquid crystal in the middle...they can take touching but it is not recomended to push too hard...as for cleaning they usually have an anti-glare coating and you don't want to use any type of abrasive or anything containing amonia or alcohol as that can also damage the screen....from personal experience I would recomend getting a micro-fiber cloth to clean the screen....I found out how good it worked and will never go back to anything else
edit: forgot the second question....pixels normaly won't "go out" over time....if they are dead they are usually dead from the get go...as for lasting...the major component that will go out is the backlight and that all depends on how long you leave your display on....if you aren't using it turn it off....they are a CCFL lamp that is the width (or sometimes height) of your display and all of about 2mm in diameter...they can be replaced but you need to know what you are doing and where to get the parts
LCD's should last very long if it's of good quality and treated properly. I have a Viewsonic VG150 that says it was manufactured in August of 1999! And I used it *everday* and *all* day, and it runs great. No dead pixels, nothing. So i'd expect more then 2 years! I just replaced it though today with a 19 inch LCD... no more 15 inch for me!
And I always clean the screen, and my laptop's screen, with a slightly damp cloth. Just water, nothing else. DO NOT use any alcohol based cleaners, or any type of liquid that wasn't specifically made for an LCD screen! I've heard it can ruin the screen. ...But why even buy cleaners when water is free and works great!
Edit: Don't touch your screen. Not just because of the chance of physical damage, but the oils on your hands are tough to remove from the screen... so try not to gunk it up if you don't have to.
