mr. texas said:10 Ghz processors?
3 Ghz Vid cards with 2 Gigs of Ram?
1 Terabyte HD's with 128 megs of cache?
whats the deal?![]()
mr. texas said:Smp?
Master [H] said:In 2010, we'll all be laughing about how 4GHz is so slow.![]()
JulesBravo said:With the falling costs on synthetic diamonds in 5 years I believe we will begin seeing the first chips using diamonds, and a rapid increase in speeds, quite possibly in the 50 Ghz range. Diamonds run so cool that you can do practically anything with them.
darktiger said:We will have 10ghz ORGANIC processors.... Then we are going to have nanoCPU, then one day the nanoCPU's are going to work against us, sending us back to medieval times....
that might even be trueblackrino9 said:6). Half Life 2 and Duke Nukem Forever will be out just in time for Christmas
Redux said:Well, assuming Microsoft can get Longhorn out by 2010, we should be seeing fully 64 bit native applications and maybe 6-7 GHz processors on the top end, and 4 GHz will probably be affordable for the average user.
I think more than anything we will probably see a revolution in motherboard design by then. Right now the choke point on most computers is the motherboard, and a new more efficient motherboard design could go a long way to improving performance.
DeFex said:1 Terabyte HD's with 128 megs of cache?
Easy! if we still have to use nasty clunky mechanical parts in our computers
Non-volatile RAM technologies which don't wear out easily (like Flash) have already reached where prototypes are produced. MRAM is already being used in a limited number of applications.SB22 said:Seriously, i really hope HD's are a thing of the past by 2010. I'd be nice if they had something that was faster and more reliable. I just see too many HD's dying at work, makes me just feel like I can't trust the things.
My SED displays beat up your LCDsomega-x said:how bout LCD's that are dirt cheap, have no dead pixels, and are as good, or better than professional CRT's in terms of refresh rate and color quality/response.
add in some HDR contrast ratios, perfect blackness with no "mirror coat", and 1600x1200 as a standard for 15-19" inch models. (as some laptops have)
MRAM could also be defined as magnetic storageolaf2821 said:[..] and I hope to God that SSD's finally replace magnetic sotrage [sic], [..]
