I'm naming Virtualbox but what I mean is how far can I go with a virtual machine inside Windows 7 and how do I do it?
The problem is I need to run DOS pcb design program, which refuses to run in XP or Windows 7. The last time I used it, with no problems, was with Windows 98.
Another option would be installing Windows 98SE on a smaller HD, but I am not sure it will work with modern hardware like mine.
What do you suggest?
