The first 2 ms response time TN came out in 2005 and the first 1 ms response time TN came out in 2010.
I think the fastest IPS is still only 5 ms. You probably have a long wait if they ever even get that fast. OLED will probably completely replace LCD before it happens.
I would think something entirely new will happen before this. 1ms has proven incredibly hard for manufacturers of IPS. They'll get close to 4ms and it gets out of control real quick. All IPS needs is 120Hz. 4-6ms is fine for pixels. Something other than LCD would be nice instead of chasing matrix switching times.
I don't think it'll be until around the early 2020's that OLED's will beat LightBoost motion clarity (fixes the LCD sample-and-hold problem) while also simultaneously being bright enough and inexpensive enough.OLED will probably completely replace LCD before it happens.
This is Chief Blur Buster of BlurBusters.com....If you did 120hz on a 5 ms LCD then for each frame you would have 5 ms of blurry pixels then 3 ms of correctly colored pixels. That is a lot of blur.
