you give the KVM an IP address so you can always connect to it
that way you can see everything on the computer as if you were standing there - you don't have to wait for the computer to boot in order to connect to it
the KVM has the IP address and it is directly connected to the machines via cables... you connect to the KVM not the machines
make sense?
only the kvm box gets an ip, the kvm handles all the pc connections using cat5 to kvm dongles
That's usually a safe assumption, but it's not a hard and fast rule. In most of the IPKVMs I've worked on, it's a single IP per KVM ( or even KVM stack ). But some of the equipment I worked on a while ago allowed you to assign each attached system it's own IP to access the KVM.thanks guys very informative so 1 ip to the ip kvm switch to access all the connections
Likewise, you will access the KVM via web browser....usually. However, there are several brands out there that have their own client app that has to be installed on the administrative workstation ( which is always fun, especially when it's written in Java...by what I assume are first year programmers ).
The core concept to understand with IPKVMs is that the local console of the attached systems are made available to the network...somehow. Everything else is a variable related to the brand and model of device.
correct and I believe you can either enter the settings with in the access of a browser or you have to download one of the kvm manager client software on your computer
You can get some Avocent models for like 50$ from ebay for 16 computers but the remote console sw isn't free :E
There seems to be HP branded one's for 125$ and they seem to have HPs own management software.
ahem torrent...
So it's a similar concept to IPMI?
(as far as benefits to the user?)
