Well, to put a long story short, in the process of pulling my Zalman 7700Cu off my 3800+X2, I yanked the processor up with it. I bent a few pins near one of the corners (there are two corners lacking a few pins, as I recall, and it was the corner without the arrow). By sheer luck there were only maybe 4 or 5 pins bent, and they weren't bent too bad - 35 or 40 degrees at most.
After some careful bending and a couple trial inserts into the socket, I got it back in without losing any pins at all, and it still operates perfectly. But for peace of mind, I would just like to know: would you really have to wiggle those pins pretty hard to pop one off? My friend has a 3500+, and he actually, in a similar event, bent an entire side row a tiny bit, as well as one pin going a full 90º to touch the side. His processor, too, is working just fine. Does the locking mechanism straighten the pins out again? Is there any risk they could pop off in the future (I don't plan to take it out again unless I'm replacing it) through heat or something? (My guess is no, but remember, this is just for the sake of peace of mind ). Any risks of overclocking, or any risks at all?
Thanks. Kind of a scary event, I'm just glad none of them were seriously bent.
