Just curious to see what you guys think about this. Getting a Thermaltake Xaser Armor case , mounting a 77' Bonneville w/ AC heatercore in the front, mounting 3 120mm in the front blowing through the heatercore, and having 1 120mm, and 2 90mm in the existing holes to exhaust the air.
Now because I would be using the heatercore with AC, it does fit into 5 1/2" bays, and I was thinking this would be a great idea.
There would be no need to cut the case (perhaps think of some way to secure the heatercore, but because it would just stand there, you just need some brackets to keep it in place), and the system would be so much airflow through, and it's nice because it has the hard drive brackets up at the top with it's own 90mm fan.
Let me know what you guys think.
