I'm looking for comments on this purchase before I place my order at Newegg. I need a PC ASAP...AM2 doesn't seem like it is worth it now (DDR2 is more expensive, not many motherboards to choose from). I know Conroe is suppose to be great and all, but how long will I actually have to wait before I could find a motherboard at a good price? Correct me if I'm wrong in thinking this way...
Specs:
NEC 16X DVD±R DVD Burner 3550A - $35.99
SAMSUNG SpinPoint P Series SP2504C 250GB 7200 RPM SATA 3.0Gb/s - $79.99
(I thought about the WD250KS but was wanting a quiet hard drive...they should be comparable in speed, right?...even though the WD has 16MB cache.)
ASUS A8N-SLI Premium -$159.99
eVGA Geforce 7900GT KO - $274.99 (-$15 rebate, $259.99)
Scythe S-FLEX SFF21D (800rpm) 120mm S-FDB fans - $14.99 x 2
Air Flow 33.5CFM
Noise Level 8.7dBA
G.SKILL Extreme Series 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 500 (PC 4000) - $179.99
Would it be better to go with the OCZ Gold GX? I think it has better memory timings (does that even matter?) but they cost a little more before the rebate.
AMD Athlon 64 3700+ - $235.00
I plan to OC this at least some, which is why I went with the higher speed memory. Would it be worth it to get an aftermarket cooler? If so, which is the best cooler for the price?
After shipping, before rebate: $1,016.09
I also ordered a 2007WFP...hopefully that banding stuff won't be an issue.
I already have a case and power supply that should run this fine.
Thanks for your comments.
Specs:
Air Flow 33.5CFM
Noise Level 8.7dBA
