How does this look?
ProXie
Basicly I just fixed up this comp.. Its running an AMD 1.1GHz processor, 1 fan, a 250w PSU, 1 20gb hd, 1 80 gb hd, 512MB of Ram in SDRam ( Its an old comp ). I installed speedfan and I'm not really sure if these readings are good or bad. I'm not sure what the temp1, temp2, and temp3 are. Here are some screenshots.
If someone could explain to me what all this means that would be great. I'm planning on leaving this comp on pretty much 24/7 so I can run a game server on it. Do you suggest I buy another fan for it? It looks to me as if the motherboard can hold another fan b/c when I go into the fan spot there are 2 fans but one fan is running at 0RPM? Is that an open spot? What do you think I should buy. I'd like a cheap/silent fan and maybe a fan controller.
well dude, the first diagram, it seems to me that the first temp reading is the amd chip, second is the case, third looks to be the PSU, and if it isn't plugged in, it could be some other reading, not sure, your going to have to tell me if the PSU fan sensor is plugged in or not..... your rails look great on the psu so i don't know why the hell it would be reading 144c...... something isn't right there.... other than that you should be good, looks fine, im taking it that the PC is in excellent condition?
I don't use that program, but it seems easy enough to figure out. Temp1 is the CPU, Temp2 is the mobo/northbridge (which is apparently on fire, and definitely wrong), and Temp3 is your ambient case temp. Again, just a logical guess.
BTW, your rails look good from that PS.
ah the northbridge, completely forgot about that, yea, check and make sure that the fan is plugged in correctly on the NB;)
I'm pretty sure the fan is in the correct spot. Anyone suggest a differant program to give my computer's tempatures that is easy to use and free? I'm really concerned lol.
On sisandre where can I go to get the temp of my processor etc. I basicly want a summary page with the tempature of everything.
yea, just click on the mainboard and processor information, and scroll about half way down and it will give you the place and the temp, also it will give you many other readings
