How does this look?
Piph05
Gaming
850
3) Where do you live?
PA
4) What exact parts do you need for that budget?
CPU Mobo GPU Ram PSU Case HD OS
Dvd Drive Monitor Keyboard Mouse Speakers Headphones Ethernet Card
6) Will you be overclocking?
Probably Not
22in
This week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing special
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
No
Ok this build is for my younger brother, he has a budget of 850. He mainly just plays wow right now, but he wants a new computer, so this is what i put together.
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119161
HD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145218
Video card + PSU
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.349522
CPU + Mobo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.345242
OS
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
This comes out to 845.92 before tax. Any changes you guys would do, or anything I am missing? Thanks.
I was actually considering going with the cheaper processor. Is that really that much of a difference performance wise between the two?
Unless you deem that 400mhz of power and having an unlocked multiplier is really worth the $50 difference then no there is little difference (both could be O/c'd to 3.8+ with proper air cooling). Plus the 95w version will run much cooler. My main concern with your build was the PSU you chose.
hd's build is good. i'd change the hdd to an f3, though, if one is in stock. hm... not sure what you listed in your op since you didn't mention any parts... too lazy to click on a half dozen links.
