How does this $1300 build look?
Dergrin
I am building a completly new computer that will be used for gaming and graphics work. I am aiming at getting the most bang for the buck and plan on overclocking. I also plan on running Vista Home Premium. Let me know if you have any suggestions.
Case: $67 + $18 S/H = $85
Antec Solo Black/Silver Steel ATX Mid Tower Computer Case - Retail
Motherboard: $139 + $0 S/H = $139
ABIT AB9 QuadGT LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
Processor: $186 + $0 S/H = $186
Intel Core 2 Duo E6420 Conroe 2.13GHz LGA 775 Processor Model BX80557E6420 - Retail
Video card: $269 + $6 S/H = $275
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB GDDR3 PCI Express x16 HDCP Video Card - Retail
Memory: $110 + $5 S/H = $110
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400PHU2-2GBHZ - Retail
Monitor: $240 + $15 S/H = $255
Acer AL2051W Black/Silver 20" 8ms DVI Widescreen LCD Monitor - Retail
DVD burner: $39 + $6 S/H = $45
SAMSUNG 18X DVD±R DVD Burner With 12X DVD-RAM Write, LightScribe Technology Black SATA Model SH-S183L - OEM
Power supply: $85 + $10 S/H = $95
CORSAIR CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W Power Supply - Retail
Hard drive: $70 + $0 S/H = $70
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
CPU cooler: $25 + $5 S/H = $30
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
Total Price = $1290 including shipping
ds3 > quadGT for single video card setups like yours cause it is both cheaper and better at overclocking.
with the $40 you save get the 640MB version ($75 more) and you will top out at $1325
^The DS3 is slower and doesnt use the ICH8R chipset so the onbaord RAID isnt as good as the quadGT. The QuadGT also overclocks great.
I would however offer the suggestion of going with a 4300 for the CPU and using that money for either A) saving it, B) getting a better graphics card, or C) going with a P35 chipset. Going with the P35 chipset will open up a better CPU upgrade path. The choice really depends on your specific needs. The 6420 costs about 60% more than a 4300 yet probably wont offer more than 15% more performance (with overclocking being considered).
Also, as far as you case goes.. I would suggest something with both a front 120mm and a rear 120mm (avoid the loud 80mm fans at all costs), I don't think the SOLO has a front intake fan (could be wrong).
I'd suggest this monitor instead: SAMSUNG 225BW Black 22" 5 ms (GTG) DVI Widescreen LCD -- $290 - $20 rebate
I do not want a TN panel. I will be doing some graphics work and need a decent monitor.
Also I have looked at the DS3 and considered it strongly. I really like Abit and heard the Quad GT was a little bit better, however I dont plan on using raid. If that is one of its main advantages than I could go for the DS3. Also, which DS3 the rev1.3 or rev3.3 because there is a $30 difference?
I have also been thinking about dropping to a E4300. And my upgrade path is usually every 3-4 years so I doubt that the P35 I get will still be good then.
Any one else have ram suggestions? Bassballboy, your link is bad.
Thanks for the suggestions.
My apologies, the links I put up for deals will go quick, as they're usually super deals.. Stay on top of websites like fatwallet.com slickdeals.net and dealsofamerica,com for deals on ram. For instance, that dead link was for DDR2 1066 RAM for $85… if you keep your eyes open, they'll run DDR800 ram for $80 or less.
this is an ok deal, but I'd wait for a better one:
http://www.buy.com/retail/Product.asp?sku=203064652&adid=17662
oh, and a little fyi on ram though, tomshardware did a test where they tried different ram's, 800 up to 11XX or whatever, and essentially you wouldn't be able to tell the difference amongst them... just some food for thought
