How does the Gigabyte Silent x800xl Stack up?
dpoverlord
1+ Page OP OG Club
I just ordered Gcard Gigabyte X800xl Silent cooled card for the new system I am building which will be:
Motherboard DFI Lanparty ULTRA-D
Chip 3200 Venice
HSF Retail
Gcard Gigabyte X800xl Silent cooled newegg link
Psupply OCZ Powerstream 600 Watt
Ram OCZ Winbond model 2x512 OCZ4001024WV3DC-Knewegglink
Case Lian Li PC-70 USB
Hard Drive my old 4 160 GB PATA maxtors
monitor IIyama 512pro
my case is
Pic 1
Pic2
I did spend 300+$ on the video card so if lets say it was in the 200-250 range how does it stack up. I figure I have enough cooling in my case I am still trying to reconfigure the fans for the mosto optimal cooling. I have a digi doc 5 on there which puts certain fans on when certain parts of the case hit low temps. So what do you think about the card?
Good thing you got the 'Silent' video card. Otherwise your GPU fan might make your case even louder. :rolleyes:
I have one of those and love it. One bad thing about it is that you really can't overclock it. But then again it plays everything I throw at it at the highest settings.
The one I am buying has the shim taken off and has artic silver on it for a stronger hold. I am under the understaning that this will void the warranty. Do you feel that I should have any worries? I really wanted the silent card since the case can get pretty loud :-P.
