nytrackstar
- Aug 3, 2004
well, topic says it all...hows does RAID-5 Compare to Raid-0 and Raid-1 speedwise..
defakto said:Raid 5 performs at roughly the speed of raid 0 of n-1 drives where n is the number of drives in the raid 5 array, for reads, for writes, it usually performs close to a single drive.
why do you need 150GB for each OS?nytrackstar said:Controller: PROMISE SuperTrak EX8350 RTL PCI-Express x 4 SATA II Controller Card Link
i was thinking of configuring a multi-boot subsystem, original plan was for 2 150gig raptors in RAID-0, 150gig for each OS (XP64, MCE)
with vista coming along i figured i could setup the array with 3 partitions, 100 gig for each OS and leave one partition unformatted until vista arrives...
mulling it over it seemed a bit risky to have 3 OS installs all on a RAID-0 but raid-1 wont give me enough space so RAID-5 was a consideration (only have to buy 1 more drive) but it will mostly be used for gaming so i'll probably stick with the raid-0 and image all 3 partitions onto my ~2tb raid-5 storage array weekly...
EnderW said:why do you need 150GB for each OS?
