How does my build shape up?
After my last system gave up the ghost, I've been using a laptop for about a year. Built the kids computer but can't use it. Now it's my time.
I've thrown together the following wishlist, and will be ordering maybe today..
Let me know your thoughts/suggestions
Case-
Antec Nine Hundred
PSU-
Corsair 620 Watt
Mobo-
EVGA 680i
CPU-
Intel QuadCore QX6700
Memory-
2 Gigs of OCZ DDR2 1066
Video Card-
BFG 8800GTX OC2
Hard Drive-
Western Digital Raptor SATA 150GB
Sound Card-
HT Omega Claro 7.1
DVD Burner
Optical Mouse
Keyboard
Windows XP
It will be a gaming computer, probably will stay for at least 3 years. I went with SLI so I can drop in another 8800 in a year or so. As far as I can see it is all Vista Upgradeable, but I have no interest in Vista right now. I am a bit torn on the quad core CPU decision. I will OC it, but I'm not up for a Watercooling system right now, so it will have to be mild. I figured with the QC I may have a bit more future usability, since I'm sure I won't upgrade again for a couple of years.
Any input is appreciated, I'm looking for glaring oversights or incompatability issues.
Thanks
Whooah,
This is a very active board but you can't always expect a reply immediately :)
In any case, it looks like a good setup. Some questions though before you pull the trigger.
1) What's your budget? I assume it's > $2000 as you're planning to purchase very high end components.
2) PSU? With a quad core and an 8800 GTX (with the possibility for a second,) the PSU becomes a critical component. It's very important to buy a quality model that has enough juice for such a monstrous machine (think 700W-1KW.) For best advice, consult www.jonnyguru.com for excellent PSU reviews.
3) How much do you plan to overclock? I noticed you didn't list an aftermarket CPU cooler. Note that current Quads don't overclock as well as Dual Cores, especially with stock cooling.
4) This is my personal preference, but a beastly system calls for a grand case. Look at Lian-Li or Silverstone for the best of the best.
5) Are you planning on just getting the raptor as your only HD? I find 150Gig to be extremely small these days.
Otherwise looks good. Good luck,
Mark.
Thanks for the reply mark,
I want to stay under $3000.
My simple math put the PSU as adequate, but I see it will be at the ragged edge or inadequate with the SLI. Do you have a suggestion for a PSU?
Yes I will OC, and I was hoping with my case choice, (huuuge fans and lots of airflow) I could do a modest OC with an aircooled system.
Yes raptor only to start, plenty of room for more with the Mobo and case as I can tell.
No?
Oh, looks like I forgot the PSU on the original thread,
this is the one I was to order
Corsair 620 w Power Supply
I would definetly ditch that PSU in favor of a beefier unit. I have Silverstone Zeus 850W model that's been perfect for my power-hungry rig. The Enermax Galaxy and PC Power & Cooling 1KW model are very popular 1000 watt choices.
As mentioned above, you can't go wrong by swinging over to www.jonnyguru.com for PSU reviews. Silverstone, SeaSonic, and PC Power & Cooling tend to make excellent units.
As for the overclock: Every chip has it's own individual characteristics which effect overclocking potential, so as the saying goes: "your mileage may vary", no matter the chip you buy. Even with an Antec 900, I probably wouldn't settle for the stock cooler (given your budget and the other components your planning to buy.) For best of the best, look at the Tuniq Tower or Thermalright Ultra 120 (note that with the Ultra you'll need to supply your own fan.) The Scythe Infinity is also a worthwhile cooler.
Good luck,
Mark.
I don't think the QX6700 is practical, even if you want to keep the system for 4+ yrs. A CPU only upgrade is rather small, and would be more worthwhile when the prices on quadcores become more affordable, as quadcores become more mainstream. The Q6600 is set to drop to $266 near the end of the year. An E6600 right now would be faster, and only cost you $235 (as opposed to a Q6600). If and when you want quadcore, grab a Q6600 and sell the E6600 to help offset the cost. If you don't agree with my practical thoughts, then I'd suggest the Q6600 instead of the QX6700 at least.
The Corsair is a great PSU, but the quadcore plus SLI puts it over the top. While it CAN handle 8800GTX's in SLI, a quadcore on top of that is pushing it with a couple drives. Go for the Zeus 850W Mark suggested.
What size monitor do you have? SLI is only needed for 24" or larger LCDs. IMO, SLI as an upgrade path isn't worth it unless you will be upgrading to a large LCD screen. There will always be a better single card solution. For example... I could sell my 7800GT for $150 (instead of buying a second card for that same price). That would give me $300 to buy an 8800GTS, which outperforms a 7800GT setup. If you have a 24" or larger, I'd look into at LEAST a single 8800GTX.
BTW, you don't need DDR2-1066 for either quad core CPUs. DDR2-800 is more than enough, and DDR2-667 is ideal. Here's some math for you:
QX6700: 10 * 266 = 2.66Ghz, DDR2-533
overclock: 10 * 300 = 3.0Ghz, DDR2-600
Q6600: 9 * 266 = 2.4Ghz, DDR2-533
overclock: 9 * 333 = 3.0Ghz, DDR2-667
I agree with mark... for such a nice build, it deserves a better case. I just don't think the nine hundred is classy enough. The TJ-09 is ideal, but even a Lian-Li V series would be good. Theres also the TJ-06 and TJ-07. The CM Stacker series and Tt Armor Series are also popular.
