For the Core 2 Duo chips...
I know that memory speed is often quoted as the DDR values (533, 667, 800,1000 which is really 266, 333, 400 and 500) so the Non-DDR speeds multiplied by the CPU's multiplyer is the clock speed for the CPU (for example E6600 is 266x9 = 2394 or ~2.4Ghz).
Now the "quad pumped" part has always confused me, we're talking 4x the Non-DDR speed of the RAM which is 266x4 = 1066Mhz.
However when you use faster ram to overclock, i.e pruchasing some 667/333 like I have done means I can get my CPU upto 333*9 ~= 3Ghz
But does this mean the front side bus between the north bridge and the memory is now 4x333 = 1332Mhz or is this controlled seperately?
Also aren't the other busses, the PCI express and the PCI busses fractions of the main FSB, in which case don't they get higher also? I'm assuming most mobo's can lock these speeds in place rather than it strictly being a ratio, so it's always the right speed?
Anyhow a little light shed on the situation would be great, my E6600 and mobo is already here but I'm waiting for some replacement RAM since the OCZ stuff I got doesn't work in the motherboard
Thanks for any help!
