Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
it works just like the system idle process (look in the task manager, process tab). it takes what isnt used and uses it. the main server has data chunks that you download, the prog crunches the data, and send the results back. more info in the distributed computing section...
