EvanWasHere
- Apr 24, 2008
This is beyond horrible. I bought this board for my dual E5430 Harpertown CPUs (2.66Ghz Xeon quad core 771 socket w/ 12MB cache each). I wanted the latest and greatest and heard great things about the Skulltrail motherboards. To my horror, I have had one problem after another.
The first, was that the aftermarket CPU cooler wouldn't fit the board. http://www.acousticpc.com/noctua_nhu12p_xeon_cpu_cooler.html I did the research on the best heatpipe Xeon quad core cooler and made sure that it fit my case, but since the motherboard was so new, I couldn't check to see if it was compatible. Sucks, but I can deal with that. I used the OEM heatsink/cooler from Intel.
Then, the PSU I had, second 12v cable wouldn't reach to the second port on the motherboard. In fact, 3 other PSU's I tried wouldn't. Why both 12v slots are so far away from each other on the motherboard is a mystery. So, I had to ghetto fashion a temporary cable until I can receive a real extension cable.
Then I tried to install Win XP Pro on the WD Raptor HD I had gotten for this system. I spent a total of EIGHT work hours trying different Raptors, different cables, different BIOS settings, until I returned here and found a review on newegg posted a day after I purchased the board that says the Raptors do not work. So, I put a regular 7200RPM HD in, and was able to install Windows.
But to my dismay, when i rendered on this machine, my speeds were SLOWER THAN A SINGLE DUAL CORE 2 2 Ghz machine??!! This machine has 8 cores!! How can a $1,000 PC render faster than a $3,000 one? This can't be right. I Googled this motherboard and found a forum (http://www.xtremesystems.org/forums/showthread.php?t=183499) describing the same problem. The board was operating at less than half speed. I then saw another new review on newegg with the same thing.
I paid $500 for this board, and have spent a total of 3-4 days now WASTING my time on this new workstation I have built. I get paid on a per hour basis. I have lost 32 hours of working trying to get a board full of bugs working. Who releases a board with soo many problems??? And when I called Asus tech support, they had heard of the Raptor problem (of course not putting an update on their forum or website to alert anyone), but had not heard of the speed issue (while other people on the net say differently).
So, my question now is, do I wait for a new BIOS update? Could it fix the Raptor and speed problems? Will they release it soon? Should I just give up and get another board, and which should I get? Any suggestions?
(2) Intel Quad Core Xeon E5430 Harpertown 2.66GHz 12MB L2 Cache LGA 771
(1) ASUS Z7S WS Dual LGA 771 Intel 5400 SSI CEB Server MB
(1) Kingston 4GB 240-Pin DDR2 FB ECC DDR2 800 (PC2 6400) 2 DIMMS
(1) WD Raptor X WD1500AHFD SATA - 150GB - 10000rpm
(1) Thermaltake Armor Series VA8003BWS Black
(1) Thermaltake W0131RU 24 pin, 850W Power Supply
