how do you....with a TV tuner?
Name9902
i'm having a bit of trouble in that i cant seem to get audio both with the tv tuner and the actual comp.
anyone have ideas on how to get audio with both, in some effect splitting it?
seems i fixed it, just gotta use a dual male 1/8 connector in between the blue port and the port on the tv tuner...
which brings me to my next question :p whats the blue plug used for on modern pcs? pink is the mic and green is the general speaker, what about blue tho?
Blue is usually Line-In. Used to transfer sounds from any non-amplified source through your sound card to be recorded or back out to your speakers. Supports a wider range of sound than the microphone too (try playing back inputs into the microphone, and you'll hear the difference).
I have my PS2 hooked up to my shuttle through my Line-In + Y Adapter. Works great.
