Red Squirrel
- Nov 29, 2009
I'm trying to update a Unifi AP due to that wifi vulnerability that was discovered. I did manage to upgrade the AP and it is at version 3.9.3 according to the busybox prompt. (I'm assuming that's same as the AP version?)
Problem is, now it won't adopt it in the controller. It's just stuck at adopting. Seems to be a common issue. I presume I need up upgrade the controller too, it's at version 3.2.10.
I downloaded it but it's a .deb file, the server is CentOS so it's not debian based. I tried to extract the file with dpkg but all I get is a usr, lib, and etc folder. My existing controller is java based and just has a bunch of jar files in a folder. I was hoping I could just replace it and that it would give me the newer version but clearly not the case.
I can't find instructions anywhere on how to do an in place upgrade, anyone know how?
I did find instructions on how to install from scratch and it involves using apt on a debian box so worse case scenario I'll create a new VM with Debian and do another controller from scratch given I only have one AP, but wondering if there is a way to upgrade my current one.
