How do YOU store all your computer parts?
It's a simple question, I'm wondering how you guys store all your extra stuff. I've collected so much junk that I can't throw away, parts to cases and stuff that someday I could need. All this stuff is different in sizes. Right now, I have it all sitting in boxes (sizes vary, but around the size of a 15" crt monitor box). I have to dig around in them to find what I want.
So, you guys got any better ways of storing?
Muchas gracias!
all nics in one box, all video cards in another, all ram in another etc. if you go to usps.com you can order free boxes that are great for storing stuff (and shipping it to ;))
for cases etc. i just stack them up in the corner somewhere
Shelves, and lots of them. I have 2 shelves of CRTs, TVs, and other assorted monitors. Another shelf of internal components, and one of peripherals...
How do you sort those internal components and peripherals? In boxes like #2?
I put them back in their orginal box and in my closet. I really dont use the closet all you see is a pile of cloths in the corner.
Korialstrasza said:
I was thinking about a couple of these, but they're kind of expensive...:(
http://www.officedepot.com/ddSKU.do?level=SK&id=551048&N=201569&An=browse
Those would be fine for cables, screws, wires, bay covers, etc...
I would NOT put any video cards, RAM, CPUs, etc... in there though. Please see my ESD post in the electronics forum for explanations. I wouldn't even get my electronics NEAR that storage device you posted.
To be honest, I use a very similar stack of shelves for my storage. But I don't have any electronics in it.
all nics in one box, all video cards in another, all ram in another etc. if you go to usps.com you can order free boxes that are great for storing stuff (and shipping it to )
Just ordered 20 (max). Thanks dude! :cool:
In the bottom two droors of my dresser. The more important parts are in anti-static bags, everything else is wrapped in TP to keep whatever from banging against whatever and breaking whatever.
Spare bedroom. Stacked literally up to the ceiling. Can't even get to my server any more.
I really must dispose of 90% of what's in there. Don't think I'll be needing an ISA sound card soon :)
-Larry
Muchas gracias!
Actually if you have a Big Lots around they have something similar to that for alot less.
mixed.....some are in bags, other things are on a shelf.....it's one of my goals to get it all organized before we move in a few months, so it is easier to move, plus I hope to get an office, so things will be better organized.
So, I've got some organizing /cleaning to do!
Those drawers rock though!
I also got the free USPS boxes in less than a week! Like you guys suggest, all my hardware parts will be going into those boxes, not the shelves.
Im a pack rat and keep all the orginal boxes and packaging if its like a plastic insert or foam insert. For the other misc stuff, I put it in baggies usually as they usally are just case parts, screws, etc. If its a part I dont have a box for I find a box for it.
Did you select 2 under the quantity option? You mentioned that the max was 20 boxes. I ask because on the check out screen it says Format = Pack of 10. So if I put 2 in the quantity field I get 20 boxes right?
I just toss everything into a pile. It only takes up half a spare bedroom.
What I actually CAN use though, all goes toward
