how do you stealth drives in chieftec cases?!!
Bboy_Jon
How the heck do you stealth your drives with the chieftec cases? they use those stupid tool less things for your 5.25 drives but then how the hell do you stealth them?
The same way I stealth my Shuttles only a little different. Take a dremel and cut off all the side groves and channels on a faceplate for the case so its a perfectly even sheet of plastic.
Remove the CD drive tray cover as it usually snaps into place. This will give you a nice even suface because most CDROM drives rarely have flat face drive covers. Then, put on 1-2 layers of double sided sticky tape, slap the plastic bay cover on, slide the CDROM into place and adjust for gap distance, and wallah! All you need to do is simply push the corner of the drive face to open the drive.
This guy used sticky blue rubber that you had back in school but the results are the same.
hm...take a look at the hard drive rails, those tool less thingies. you should be able to drill 4 holes so when you slide them in, it should give you enough room to stealth the drives
Most, like the Antec ones have multiple holes so you can position the CD drive just right, so that shouldn't be necassary unless its a total POS case.
ya i still want stealthed drives cuz my door wont cover crap
ya i figured it out like a min afte ri posted but i didnt feel like going back to the forums to say it
i didnt know the mounts go inside the bezel (in other words the mounts get put on first then the bezel
