I've seen on here repeatedly how people have taken a flat piece of plexi applied heat to it and have bent it into boxes.
How do you do that? What are you guys using to make the bends? Straight edge? Piece of pipe? What?
I'm asking because I'm trying to make a box that is approximately 1 1/4" high by 5 1/2" deep by 8 1/4" long. I just went into my shop, took a pice of cardboard 21" long by 2" deep and measured it up. Folded it and made sure everything was correct.
Then I took my piece of plexi, marked it up where all the cuts and folds were supposed to be, cut it out. Then took my trusty torch heated up the plexi and used a vise to help bend it. The first bend came out a little shorter than I wanted. But I continued. Heated up the plexi then used a ruler to bend it. I put the ruler where I drew the line and bent the plastic. Still, it didn't bend where the line was it bent a little above that.
Needless to say. The box isn't much of a box since nothing lined up once I applied heat to it. It warped a little which isn't a big deal.
Where it doesn't line up is where I measured for the bends, even though I used my template to make the marks. So, everything theoretically, before I applied the heat to it was right where it needed to be.
It ended up being the right depth of 5.5" and on one end it was close to being 1 1/4" the other end was way off and it ended up being about 7 1/4" long with almost a 2" overhang.
What happened?
When I draw my line where I want my fold to be do I apply heat to that line or do I move it 1" or so back? Do I use a straight edge to fold the plexiglass? Or do I use a pipe or something with some mass?
I have just enough plexiglass to do this again, but...before I start I want to get some input as to where I'm supposed to be applying heat and where I'm supposed to be bending and how and with what tools am I supposed to be using to bend with.
And before you ask what the small box is going to be used for heres your answer.
I'm removing my 2 SATA HDDs from inside my case to a remote box outside of the case. I have a hub which gets attached to teh back of the case where I can run the wires from. I have the wires in some flexible tubing that will be attatched to the back of the case and run up to the satellite box ontop of the tower. It'll be fastened to the top of the tower so it doesn't move. The box is going to be made out of plexiglass and carbon fiber the plexi since it discolors when heated will be painted black to match the rest of the case.
What happened?
