How do you oc a MSI mobo?
rjolin01
anyone ever oc a msi p7n SLI -fi mobo or similar bios set up. its different then my gigabyte mobo and little confusing.
The basic options are the same across all boards, although different manufacturers sometimes use slightly different names. If you post the settings you're having trouble with, I'll try to help you out as much as I can with them.
