First, you'll need to draw/create/rip individual frames. These frames needs to be the same size. If you choose to draw it yourself, you'll need to imagine in your head or sketch the entire animation sequence, and create each frame by hand. In any case, place all your frames into separate layers in a PSD file, save, and close Photoshop.
You then load ImageReady, and in the Animation window, click the small arrow and select "Make frames from layers". Next, you tweak each frame's 'Delay Time', for the appropriate speed and/or pause.
