You don't have to use jpg. Try the program I suggested and find a format that works. What is the current format of the content? Also consider PNG http://www.labnol.org/software/tutorials/jpeg-vs-png-image-quality-or-bandwidth/5385/I'd rather not touch the JPEGs. If I can't compress them without losing quality, I'll have to leave it at 25GB.
PNGs, JPGs, and GIFs each have their strengths.I thought PNG was much larger than JPEG.
If the images are in JPEG they have already lost a ton of quality.
Your camera takes the RAW image from the sensor, throws away 4/5 of the data, applies sharpening (loosing fine contrast), boosts color then writes the bastard image to the flash drive.
1 wedding for me is usually 30 GB.
