maxiedaniels
- May 25, 2005
I have two Startech USB3.0 UASP bays hooked to my 2013 Mac Pro. Today I decided to try installing Yosemite on an unused drive I had sitting around. When I went to use Time Machine to backup my current boot drive, I started getting read/write errors.
This is where I'm getting lost: my SMART status on that drive says it's all good, but then the SMART status on the *other* drive in the bay showed it's about to fail. Weird, that drive hasn't had any issues. Regardless, I backed up my failing drive to another drive and removed the failing drive.
Yet, then when I go to Time Machine again, I get an unknown error ~10 minutes in. So I try to use Carbon Copy Cloner to clone my boot drive to my backup drive - CCC warns of read/write errors. What?! Ahhh.
I don't believe this is Apple specific: how do you sort out whether it's your enclosure or your drive causing issues? I'm very close to just buying a new enclosure on Amazon and returning it if it turns out it isn't the issue.. but surely there must be a more efficient way of figuring these things out.
Are Startech bays even reliable?
