How do you clean a TFT properly ?
ras2a
Is there a special cleaning product that must be used? Also, what sort of rag/cloth can be used. Obviously I don't intend to give it a wipe with my T-Shirt. Surely there must be a definitive way to clean them?
I just received my LCD from Fedex, and I went to Office depot/max, and purchased a soft cloth made for lcd's, and a spray for electronics (which is also safe for lcds) and i spray the cleaner on the cloth and gently wipe the screen with my non-abrasive cleaning cloth. There are wipes that you can use that are pre moistened and you can use those, I just got the cloth because you can wash it and in the long run it is cheaper, also the liquid is a spray that spray into a foam.
