Feb 11, 2006 #1 X xdkimx Limp Gawd Joined Jul 17, 2005 Messages 443 i have a small 92mm fan with 3 wires attached to a 3 pin female connector (1 yellow, 1 red, 1 black) how would i rearrange em to run at 7 volts? thanks!!
Feb 11, 2006 #2 madmat 2[H]4U Joined Jun 3, 2005 Messages 2,372 You don't on a 3 pin header. On that the red is +12V the black is ground anf the yellow is tach. lead. You'd hve to get a 3-pin to molex converter and hook the black wire for the fan to the red wire on the molex. +12V minus +5V equals 7V
Feb 11, 2006 #3 B BigTaf Gawd Joined Aug 4, 2004 Messages 905 made this awhile back for someone else read the above post for explanation
Feb 11, 2006 #4 X xdkimx Limp Gawd Joined Jul 17, 2005 Messages 443 hm thanks for the pictures and explainations but just to make sure heres how it looks for far: fans black wire -> 4pin molex's black wire fans red wire -> 4pin molex's yellow wire so to make this 7 volt work: fans black wire -> 4pin molex's red wire fans red wire -> 4pin molex's yellow wire (same) is that correct? thanks for the help just making sure, dont want to blow anything up lolz hmm also how should i reconnect the wires should i just strip the outer rubber skin then reconnect and patch it up with electricity tape? thanks
Feb 11, 2006 #6 R raxen n00b Joined Dec 11, 2004 Messages 23 Here is a nice article from silentpcreview incase you need a bit more diagrams, or if you want to add a switch. http://www.silentpcreview.com/article6-page1.html
