I got a TV tuner card from taiwan. i'ts from D-Link model : DUB T200. I hope this is the right forum for this question. Anyway, my question is why and do I have to use the software that came w/ the card? When i put in the CD and use the software that came on that CD the TV tuner works fine. Problem is, this software is old and crap. If i update the software from the software makers (Honestech TVR) the tuner box stops working.
If i try another 3rd party freeware program it won't recognize that i even have a TV tuner hooked up. It doesn't recognize a driver or anything. BTW this is a USB 2.0 tuner box not an internal card.
I did manage to somehow feed it into virtualdub but if i do that it gets no sound and that's just annoying
So, does anyone know why i can't use any other software besides this POS version 1.0 crap i have from the CD. Also can anyone enlighten me about what is a WDM driver? Do i have it? I'm sure i do...but it seems its used for many things. Thanks in advance, i'll reply if i get anywhere on this situation.
