how do these voltages look?
junglism
clock: 3.6 ghz
cpu: 1.2625
cpu pll: 1.54
FSB term: 1.34
dram: 2.02
nb: 1.40
sb: 1.20
temps are in the high 50's at load; prime95 stable for 24 hrs; 60 ibt passes with no errors (cpu and nb voltages to get ibt stable were much less, btw).
anything less on cpu or northbridge and prime fails.
so, do these look ok for everyday use?
thx,
nate
too much fsb term! should be good at 1.12-1.2 at most, more is bad for 45nm, at least you didnt hit auto on the p5q
