I'm considering replacing my 19" NEC MultiSync FE991SB with a HP L2335. I've never had an LCD monitor before so I'm worried about resolution issues. I've heard people say that if you run a LCD monitor in any resolution other than it's native, it'll look like crap. Is that true?
Also, what happens in both cases when you go below the native resolution of an LCD? For example, I asked someone what happens if you have a LCD monitor with a 1280x1024 native resolution and you bump it up to 1600x1200. They told me that parts of the screen will only be visible through moving your mouse to the edge of the screen so it can shift/pan over to it. If I choose a resolution below the native(1280x1024) one, like 800x600, I wouldn't need to pan to see the whole screen, right? The image will just be stretched or blown up a little?
