How Do NASA's Apollo Computers Stack up to an iPhone?
Discussion in 'HardForum Tech News' started by Megalith, Mar 14, 2017.
  1. Megalith
    Megalith 24-bit/48kHz Staff Member
    13,004
    Aug 20, 2006
    Here is a look at how modern smartphones compare with NASA’s Apollo Guidance Computer (AGC), which helped get us to the moon and back in the ‘60s. If you want to cut to the chase, newer devices like the iPhone blow away what we had back then in terms of computational power, but the AGC still arguably has it beat in terms of reliability—it was designed to be completely crash-proof.
    Yes, the modern smartphone is more powerful than the computer used by NASA during the Apollo mission, but that overlooks how impressive the Apollo computers actually were. For starters, there wasn't just one computer, there were four. NASA's computers, specifically the Apollo Guidance Computer (AGC), were at least ten years ahead of their time from a commercial tech perspective—their strength unmatched until a decade later with the advent of computers like the Apple II. YouTuber Curious Droid works through the misconceptions and gets to how impressive these computers really were.
  2. sfsuphysics
    sfsuphysics I don't get it
    13,756
    Jan 14, 2007
    man "cut to the chase" in deed... felt like an old documentary about how computers used to be made. TL;DW, the iphone is superior in every way except maybe a crash test... but then again you could put hundreds to maybe thousands of them (more so since you only need the guts) in the same space as backups, and what are the odds they all die on you?
  3. Alia Nexis
    Alia Nexis [H]Lite
    92
    Mar 1, 2007
    It's not how much power you have, it's how you optimize it to do what you need it to.
    blkt likes this.
  4. cyclone3d
    cyclone3d [H]ardForum Junkie
    13,126
    Aug 16, 2004
    Pretty good unless they are special made to withstand all the vibration of the craft taking off.
    I'd love to see a cell phone tested on a seismic testing setup. Testing on a single axis with a ton of harmonic vibration would be sweet. I'm pretty sure it would not survive.
  5. Bandalo
    Bandalo 2[H]4U
    2,660
    Dec 15, 2010
    Space-hardening for electronics isn't just having backups. It takes time to switch between the primary and backup systems, and you'd hate to have that happen during a critical time.
  6. dj_spanmaster
    dj_spanmaster Limp Gawd
    413
    Aug 1, 2004
    I don't have time to watch the whole thing. Does he eventually reference electromagnetic interference and shielding?
  7. otherweeb
    otherweeb Gawd
    860
    Jan 8, 2016
    pfft! The NASA user interface was so cumbersome. Grandma would never figure it out.
  8. tunatime
    tunatime 2[H]4U
    3,078
    Sep 15, 2011
    its amazing when you think about it. look how far we have come in 50 years just think what we they will have 50 years form now
    Jon855 likes this.
  9. JackNSally
    JackNSally Limp Gawd
    151
    Dec 7, 2011
    1-10% IPC every year or two? /s
  10. katanaD
    katanaD [H]ard|Gawd
    1,987
    Nov 15, 2016
    actually pretty good. chips that we send out to space currently are YEARS behind what you have sitting on your desk. I got to attend once years ago a "state of things" space conference at JPL and was floored by the level of CPU being used. when i inquired further, they stated that it takes many years to first harden for electromagnetic issues, then test in space before missions can start to use them.
  11. westrock2000
    westrock2000 [H]ardForum Junkie
    9,152
    Jun 3, 2005
    Considering no more humans have been to the Moon and the country that did it can't even send people to space anymore......I'm kinda sad to think how we will waste away another 50 years.
    SticKx911 likes this.
  12. drescherjm
    drescherjm [H]ardForum Junkie
    14,567
    Nov 19, 2008
    I expect the IPC improvements to end.
    Although hopefully some new materials are produced to replace silicon.
  13. [21CW]killerofall
    [21CW]killerofall Aliens...
    3,127
    Mar 16, 2006
    I believe that the Apollo computers (all combined) were about as powerful as an original Game Boy. Just about anything that has a CPU made this century is more powerful than those computers.
  14. Romeomium
    Romeomium Limp Gawd
    208
    Feb 9, 2017
    "12 amps? You can't even run a vacuum cleaner on 12 amps."
    bman212121 likes this.
  15. Dr. Righteous
    Dr. Righteous 2[H]4U
    3,152
    Aug 1, 2007
    Don't think the Apollo astronauts were concerned about playing Candy Crush on their way to the moon.
    These comparisons are flat out stupid. There are huge differences in computer designed and built for single purpose applications and a "consumer device".
    Lets compare your Iphone with the ECM in your car. The car's "brain" runs on low clock speeds and has fairly low computing power. WHY, for such a modern computer?
    It is designed to be extremely fault tolerant and reliable,. Consumer computer products, (PC, laptop, smart phones, smart TVs, tablets, etc ) are NOT very fault tolerant at all!
    Every consumer computer item CRASHES at one time or another for some reason. This is not the case with embedded systems designed to be fault tolerant.
