Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Seems like I'm not hitting the right search tags. Need to know how to tell how many WU one boxen has completed over time. Is the logfile_##.txt an indicator?
After a work unit is completed, the log usually says something like:
[16:15:20] + Attempting to send results
[16:17:22] + Results successfully sent
[16:17:22] Thank you for your contribution to Folding@Home.
[16:17:22] + Number of Units Completed: xxx
It should be accurate as long as you haven't deleted the folder and reinstalled fresh.
[05:41:38] + Attempting to send results
[05:41:46] + Results successfully sent
[05:41:46] Thank you for your contribution to Folding@Home.
[05:41:46] + Number of Units Completed: 3
If you're log file is a bit daunting to look through, its also in the client.cfg file at the end of the first (settings) section. Mine, for example says local=107.
