How am I going to fit this into a PS1 box?![]()
... you would disassemble it? You can probably find adapters that work for a single controller that might be slightly smaller, but you'll still have to disassemble it and try to fit the PCB inside the case, and you'll then have to get two if you want both controller ports to work.
No, I think that supports two controllers.
I just thought there is a solution that would involve crossing and soldering some wires..
