How do I unpartition a drive?
Foz2001
I have a drive that I partitioned awhile ago, how do I go abouts getting this back to 1 drive. (its just a spare drive, no operating system on it)
Thanks,
Foz
Either,
1) Use a partitioning software like Partition Magic or GParted to merge the partitions, or
2) Back up data, insert Windows CD, reformat the whole drive as C:
Paragon Partition v9 ( I think) works pretty well for this also. Any utility that can help you manage drive partitions can help you redistribute your space into one large drive.
gparted if you care about preserving data
otherwise you can just delete the partitions in windows and then create 1 big one.
Use windows disk manager and delete the partitions.
