How do I Uninstall?
Emberghost
Well I need to uninstall f@h but I don't know how to. When the computer is on it automatically starts and in my processes it say cpu 100% with fah causing it. I go to stanford's site and it says within a week I have had 0 total active cpu's. So when I try to delete the files it pops up a window telling me this:
Cannot delete FAH502-Console: Access is denied.
Make sure this disk is not full or write-protected and that the file is not currently in use.
I'm pretty sure it has something to do with it always running so it doesn't let me delete it. So in my task manager I end it which only lasts a few min before it starts up again, yet I still can't delete the files.
Thanks for your help.
I just delete the contents of the folder, while saving the install Program itself.
Then when you click to install the program again, just reconfigure it as you would like.
Oh and, while you have the folding widow open, hit ctrl + c to close it first, then go ahead and delete those contents.
gl:)
