How do I uninstall creative drivers?
I want to upgrade my Audigy 2 ZS drivers, but first i'm going to uninstall my current ones and run driver cleaner pro and all that. The problem is that there is no option to uninstall the drivers in Add/remove programs.
There is no need to remove the old drivers..... the "updater" will do that. ;)
Yeah, just install the new ones and it will remove the old ones and you will be good to go.
