how do i undervolt?
mrmodman
i have a amd 64 x2 3800 @ 2.5 250 X10 at 1.375 stocks volts and i want to undervolt
cpu idle temp is already at 23C and full load is 49C
what do i do to undervolt i checked bios didnt see much
same way you overvolt except go down in voltage instead of up
if you dont have option to change cpu voltage in bios ..then you cant change the cpu voltage in bios and would have to download a windows app to do it
[F]old|[H]ard
i have cpuz to moniter volts and corecenter to change volts but it dosent have a option lower then 1.35 and higher voltages
