If you're using MSI afterburner there is a checkbox in the settings menu labeled "unlock voltage control", or something to that extent. Check it and it will allow you to increase or decrease the voltage. If the option isn't there then the card doesn't allow it.
Here is a reference image,
The top bar should appear after to have checked the box in settings.
