How do I tweak PCI Latency?
MadSkills
it's causing me problems in Half life 2.
I can change it in powerstrip, but what are the tips for setting it? Trial and error is not working for me.
My vidcard is set at 248 and my audigy 2zs at 64. It's an intel 815 southbridge.
C'mon, one of you ub3r l337 [H] ppl know what these things should be set to.
I have already improved the popping in HL2 by raising it to 96 on my Creative card through Powerstrip, but I don't get an improvement for doin it any higher.
heh Renegade, I read that article too, and his settings don't work as good as the ones that I have found. But i still can't remove the pops, just reduce them.
Another question, powerstrip lists three devices for the Audigy 2ZS, the input controller, the audio device, and the firewire. they are all set to 64 by default.
What SHOULD they be set to? Is there a formula to calculate this stuff?
thanks
I don't think there is any real formula to it but you basicly had the right idea.Up the latency on the audio device and lower the latency on your video card and network card.Something is still interupting your soundcard and getting higher priority.
Try other values like 32 for vid and network and a higher value *96* for sound because you said that helped a bit and i think only the audio device listed benefits so ignore the other non major devices.
I think Omega's drivers set your vid latency to 32 by default now.
This seems to be quite a common problem with the Audigy and i find it hard to beleive that somewhere out there someone hasn't found a solution or a workaround for it. :(
I know it would drive me bonkers until i found a solution for it but i don't currently own one so i cant help a whole lot.
What else have you tried?How about your IRQ's,is anything sharing with your soundcard?
