How do i turn off vsync on 8800gts?
mtdang
Just got the new card and installed the 158.19 drivers, but I can't figure out where the option is for vsync.
go to nvidia control panel
- view on top
- click advanced
- click manage 3d settings
bottom setting
hmmm, i do not see a manage 3d settings, weird..
If you've changed to advanced... you should see a "manage 3d settings" selection come up next to "adjust image settings with preview"
When you open up the Nvidia control panel, on the top left under 3D settings is " adjust image settings with preview ". Click on this and it will open the preview setting. Look under the picture with the revolving logo and you will see " use the advanced 3D settings TAKE ME THERE ". Click on " take me there " and a list of all 3D options will appear. Scroll to the bottom of this list and vertical sync is the last one.
Click 3D Settings
Then click Manage 3D Settings
In the Global tab scroll down to verticle sync, click on Force off.
Apply and exit.
Just updated to the 158.xx version drivers and they changed it to a left hand tree-style list, which I personally like better. And my 3d settings are there :)
This is how my control panel looks like with advance settings
http://img258.imageshack.us/img258/2580/nvidcpkj0.jpg
could it be the 158.19 drivers?
Mine looks just like yours, except there are 3 choices in a "3d settings" category.
Try this:
1.) Click the Advanced Settings drop down.
2.) Click "Define Custom View..."
Is there a 3D Settings category there? Check all the check boxes you wanna see in your list, then Accept.
Try this:
Yeah, I tried that but still nothing. I installed 97.94 drivers, and the "3D settings" category is there and I can now change the settings. But my 3Dmark06 scores dropped by around 500 points.
