My full complement of WC parts finally came in, and I want to run the loop (2 GPU blocks) outside the system before I put everything in the case. Being a newbie at this, I'm looking for some advice.
I imagine that I cut the tube lengths to be appropriate for my case and hook everything up (pump, res, rad, blocks) to a PSU using the paperclip trick and distilled water.
But what exactly am I testing, in terms of leaks? Whether the blocks themselves leak? I mean, I'll obviously need to take the tubing apart and put it back together again when I place everything inside the case anyway, so it seems like I can't really test for leaks. (I'm using 1/2 ID tubing with brass clamps).
