slayer9019
- Apr 2, 2010
I have just built a dedicated (well mostly dedicated) folding box and would like to setup a dedicated client 1 per core. Is there a way to do that?
That's what I suspect, in which case I'd also use the -bigadv flag in the shortcut.im guessing a 980x or 970![]()
It's not required.Doesn't -local work too?
If you aren't planning on doing anything but fold on the AMD rig then I wouldn't waste the money to upgrade the RAM. 2gb is plenty to fold in windows.
A good speed is as high as you can get it. Folding performance scales very well with frequency so you will see performance improvements from any clock speed increases.also....what is a good "speed" for lack of a better word. me and a guy at my work both fold and we were both wondering
that processor unlocked should do some where between 3.6 and 3.8ghz.. if you can get above 3.8ghz unlocked then thats awesome but its rare.. as long as your only overclocking with the multiplier the 8 gigs should be fine.. wont have a huge effect on folding though but will help with the VM running in the background.. if you are overclocking using the HT(FSB) make sure you up your NB voltage.. some where between 1.17v and 1.20v.. stock should be 1.15v..
the i7 860 will need to be overclocked to around 3.6ghz to run -bigadv WU's if you decide to go that route.. but like dookey said run the standard A3 with your passkey until you complete 10 WU's then switch the 860 to -bigadv if you want to do those..
Well, the same thing pretty much goes. Whatever you can produce is good. With an overclocked AMD quad like yours, I'd say you should expect about 6-7k PPD.I was refering to points/day, wu/day. I want to know how much I am contributing.
It's not worth it.Do you think with a water cooled setup I could push it a bit further? Im willing to drop my next paycheck on a system if it can be done.
Buy it for other reasons and if it can be transferable to a future system, but not for folding. Use the money where it will get you superior production you will actually notice. In your case, upgrading the i7 to something faster would be much preferable to a WC setup for your AMD. Save your money for when you can afford an i7 970 and sell your 860, if you really want to see a boost..Do you think with a water cooled setup I could push it a bit further? Im willing to drop my next paycheck on a system if it can be done.
Now that's an idea! Better money spent than WC, from what people posted about the X6.well the i7 is my main rig. It handles all my real work. I can't really dedicate it for folding all the time because I actually need the resources. The AMD was a budget build (sub $190 for entire system). I am looking at the 970 for a new system but JUST finished building both my new systems (i7 and AMD) not more than a month ago. The AMD is a box I can just do whatever to. I was thinking of looking into a AMD Phenom II x6 tho!![]()
Now that's an idea! Better money spent than WC, from what people posted about the X6.![]()
I think the jury is still out on that one. You need the higher frequency processors to make very good PPD but they're also very expensive. I believe the SR-2 with dual quads will come out as a better platform in price/performance, especially since OCing is possible. If you're really focused to build a high-end AMD box for some other reason, then that's a different story.if i was to build the ideal folding machine (no GPU folding) would a 12 core AMD be the best? (i like the idea that I could always turn it into ESXi server and sell it to my faternity brothers PBX/VoIP company he owns
Understood, I think we all have been down that road at one point or another. I can't really advise you on your decision, it's based entirely on what you can afford at any given time. I am very interested in building a dual 12-core AMD system myself, especially attractive in that option is the future prospect of upgrading to Bulldozer when it becomes available according to current rumors. Architecture longevity has always been foremost on my mind.i am very split on the decision on to build a high end folding box or otherwise. what started as a budget build is turning into a box that will destroy my main rig.....![]()
1000PPD according to what? And have you completed 10 SMP units with your passkey to qualify for bonus points?I just realized with both machines going....im only getting like 1000 points aday!?!?! WTF!
Yes, it's perfectly fine.also my i7 is hitting around 84C when folding....is that ok for 24/7 use?
That's why I asked the questionsForgot to mention I am VERY new to folding.
Those 123 and 126 pointers are only classic uniprocessor WU's. Are you sure you have the smp client running with the -SMP switch??
You need to add all flags in the shortcut properties, in the 'target' section at the top following the quotations. Here's an example: "C:\F@H folder\F@H SMP\Folding@home-Win32-x86.exe" -smpi added -smp to the end of the icon name and erased my client.con file and started from scratch
