How do I set up dual monitors?
BusaOrZX12
Hi will someone tell me how to set and what hardware is needed to set up dual monitor viewing?
My current video card isn't anything special but I can use my tv in either clone or spanning mode with a S Video cable. It may be capable for dual viewing also I don't know. It has a dvi jack but I don't have a dvi cable yet. It is Nvidia FX5200 128mb that came with my dell so I don't have a manual and it is the last piece of hardware that remains from the piece of ( Censored ) dell.
Anyway one of my monitors can be hooked up to a dvi jack. Any help is appreciated. Thanks
Ok, you already have win-xp. Your vid card supports two outputs. All you need is another monitor and plug it in. If all you have or can get are analog monitors just get a DVI to VGA adaptor and plug it in.
Luck
I believe your videocard has two outputs (one DVI one VGA)...So it should support dual monitor.
Now I don't know if there is built in software, of there's a specific piece of software you need to use for this, but I'm sure someone can answer this question :)
(I believe ATi drivers let you set up dual monitors, so I would assume it'd be the same with nVidia, but not much experience with their cards so I'd wait for more input)
Thank you very much to you both. I was hoping I could have it without purchasing any more hardware. I have the monitors just need the dvi cable .
Once again.... most sincere Thanks
I also have fx5200. I have two crt monitors, one plugged into vga port and one using a dvi>vga adapter.
the monitors will work together in clone mode, but Im having trouble getting them to span. The nearest option I have is to use tv as second monitor.
Im trying to set this up on Windows 2000, which is detecting my card as a 64mb version and not 128mb version - im thinking maybe there is problem with my motherboard not detecting dual ramdac?
Also you should look into a program called Ultramon when you get your dual monitors set up...
