How do I set jumperfree mode?
Ciggarilo Himself
How do I set jumperfree mode on my asus motherboard its sorta oldschool(2002)
Also what does jumperfree mode do apart from allowing me to change somethings?
Thankyou
if your mainboard has it, jumperfree mode should be something you can click on in the bios. It is made for overclocking and will let you set FSB, Voltages, etc. for overclocking your system. Note you should turn jumperfree mode to manual to be able to adjust the settings yourself
In my BIOS
it says to change the first two cpu settings I need to set to jumperfree mode the first two settings are fsb and multiplier I can already change the fsb but I cant change any voltages or my multiplier.
Thanks.
