How do I see temperature with ntune
Thuban
Well I downloaded ntune to use the temperature monitor but I don't see it anywhere.
Once I go to the setting I can't even close the program and have to ctrl+alt+del to close down the program.
Also, how do I see the fan speed in Rivatuner? I have it on but it's always on 100% and I'm sure the the fan speed goes up and down.
There's an arrow on the bottom right that will expand the window.
to close it right click on the taskbar or the window and close
or alt f4
i have same prob with my nmonitor. the last 1/4 of the panel doesnt display, so there is no button to expand it. you have to use rivatuner or something similar.
re rivatuner - do you have ADT7473.dll checked off in plug-ins?
checking the ADT7473.dll worked. Thanks a lot vanilla_guerilla. If I could see the fan speed with Rivatuner, I don't need ntune.
