How do I reset bezel compensations? 5760*1080
onthemour
I tried reinstalling. Driversweeper and all AMD/ATI files deleted. Tried restoring to factory defaults. Nothing works. The whole screen is stuck shifted to the right.
Any ideas of what I can try?
The way I found is setting the bezel compensations and keep looking you Resolution....
when i use bezel compensation my resolution goes to 5904x1080... just keep changing until you get 5760x1080 back.
this works as well, without disabling:
Open CCC/Vision Control Center
Click on Desktop Management tab
Click on Desktop Properties tab
Under Settings -> Desktop Area -> select desired resolution under grouped
