How do I remove heatsinks from eVGA 4600
AcusticThoughts
I have an eVGA GeForce4 4600...and it has big purple heatsinks on teh ram....i dont really know how they are attached and i am not sure if the previous owner put them on himself or not....however, i dont know much about taking them off. There are no clips or anything. The heat sinks cover two pieces of memory each and it looks like from the side angle there is just a slight bit of white goo oozing over the edge...looks very dry though....the CPU cooler looks very easy with just two plastic white clips to sweet and pop off...but didnt remove because i could figure out how to get heatsinks off....knowledge anyone?
While I don't have any experience with the EGA Ti4600, I did recently have to remove the heatsink/ram sinks from a GF2 Ultra and a GF3 Ti500.
I pried them off using a flathead, philips screwdriver with a credit card protecting the surface. The GPU sink was considerably easier to remove than the ram sinks. I've also heard putting the card in the freezer in a ziploc bag can help by making the glue more brittle. That only seemed to make it even harder to remove in my case though. Maybe heating them up through use right before the removal attempt would help? You could also try an exacto-type knife to get under the sinks a bit.
